Nirjonadda
How to setup XCache with DBSEO in config.php ? Currently I am using XCache with vB Optimise, Do need to modify config.php for DBSEO Cache work ?
There are no settings required for DBSEO caching to work.
If XCache is installed and working DBSEO will recognize this and just automatically use it.
I should point out that it does require config.php modification, but only the modification that makes vBulletin itself recognise XCache. If the vB_Datastore_XCache is configured, then DBSEO picks up on it automatically :)
Is this edit is the correct in config.php for work with DBSEO? config.php modification does any problem XCache work with vB Optimise ?
 // ****** DATASTORE CACHE CONFIGURATION *****
 // Here you can configure different methods for caching datastore items.
 // vB_Datastore_Filecache  - to use includes/datastore/datastore_cache.php
 // vB_Datastore_APC - to use APC
 // vB_Datastore_XCache - to use XCache
 // vB_Datastore_Memcached - to use a Memcache server, more configuration below
$config['Datastore']['class'] = 'vB_Datastore_XCache';
 // It is also necessary to specify the hostname or IP address and the port the server is listening on
$config['Datastore']['class'] = 'vB_Datastore_Memcached';
$i = 0;
// First Server
$i++;
$config['Misc']['memcacheserver'][$i]  = '127.0.0.1';
$config['Misc']['memcacheport'][$i]   = 11211;
$config['Misc']['memcachepersistent'][$i] = true;
$config['Misc']['memcacheweight'][$i]  = 1;
$config['Misc']['memcachetimeout'][$i]  = 1;
$config['Misc']['memcacheretry_interval'][$i] = 15;
That is the correct configuration, yeah :)
It will not create any problems with vB Optimise, we're running the same setup on this server (XCache in both config.php and vB Optimise) :)
Please One More Question, Does I need to modification setup ******** DATASTORE PREFIX ****** ?
This my current configuration. That is the correct configuration ? DBSEO working work this modification setup and vBO?
	// ******** [COLOR="#FF0000"]DATASTORE PREFIX[/COLOR] ******
	// If you are using a PHP Caching system (APC, XCache, eAccelerator) with more
	// than one set of forums installed on your host, you *may* need to use a prefix
	// so that they do not try to use the same variable within the cache.
	// This works in a similar manner to the database table prefix.
// $config['Datastore']['prefix'] = '';
$i = 0;
// First Server
$i++;
You only need the prefix if you are running multiple forums on the same server, as per the instructions on that setting.
