Does your style have the template hook headinclude_javascript in it? I see the javascript call on the username, but I don't see the js script in the header.
Nice garage btw :)
If you go into ACP
ACP->Styles & Templates->Search in Templates
In the Search for Text box put headinclude_javascript and click Find
If it doesn't find it in the template then we'll need to add it since that's a default vB hook and there's no reason to take that one out.
Doh, just scrolled down and realized you are on 3.8.x
Do the same things but search for ad_location[ad_header_end] instead, it should find it in the header template
Could you give me a temporary admin account so I can login and see what's going on? It might be something not set right.
Got same problem on 4.1.1. I also checked the "headinclude_javascript" and is included in headinclude template.
Legacy Profile Hover
