Question How does display order work?
Trekkan
Since games are listed in a category (and more that one of them I think? I haven't tried), how does the display order work on the main games list page?
If you could list games by category in the adminCP, that'd make sense and then you could set the order within that category much easier.
when you are editing a game, it explains what display order is in the context of the other sorting methods. that is, its the "default" when no other specific method is chosen, and basically the same as ibproarcade's "custom sorting" method. you are free to ignore it or set them all to the same thing if you intend to use the others - the secondary sort is still by alphabetical.
the display order is global, and i dont wish to expand it per category. really, everyone will be using the other sorting methods anyway :p
Legacy vBArcade
