I've un-inastalled and deleted all the Infopanels files.
Re-uploaded 1.1.1 files and imported the xml.
Yes the bug is fixed, but Infopanels is again below the shoutbox instead of above for some reason.
The execution order for forumhome_complete IS set to 1.
Anything else for me to look at?
In that case, the only way to do it is switch vBShout to manual deployment and position it on the templates yourself.
Instance Management -> Edit -> Automatic Deployment: Disabled -> Template: FORUMHOME -> follow the other instructions on the screen.
Hope that helps :)
Ok done that. Now the Donation bar is above the stats panel.
I cant switch the donation bar to manual deployment.
Why is the behaviour different on this version?
You can manually adjust the position of the InfoPanels by turning off Automatic Deployment in DragonByte Tech: Info Panels - General Options and follow the instructions there as well.
The behaviour is different because a lot of people expressed a desire to have the vBulletin advertisements show before InfoPanels.
Legacy InfoPanels
