I believe it was only a hotfix, so the version number did not change. Yes download the file, and re upload the files and import the xml.
thanks
Re-install the script but the problem is still exist.
So you only get double paid when it exceeds the characters maximum? Does it correctly not pay you when you go below the minimum?
Thanks! that was a big hint. I think I fixed it. Download the pro package again, and only upload upload/dbtech/credits/credits_core.php (no need to import product file).
Let me know if that fixes your issue (test without the max as well to make sure i didnt accidentally screw that up either )
The problem is still exist.
By the way, this user also still has the same problem
http://www.dragonbyte-tech.com/thre...aximum-Incorrect?p=21388&viewfull=1#post21388
