Bug Post's don't appear in second instance
stig
Just upgraded to 5.4.0 .. all good so far!
I also decided to add a second instance for Moderators..
All looks OK, but posts do not appear in the shoutbox. They go into the Archive OK though??
Any suggestions appreciated.
Thanks,
Dave
I've been unable to confirm the issue in the OP.
The 2nd post, can you check to see if you've selected Font Size in the instance options?
OK, font dropdown is fixed - I missed that option .. thank you..
I've now been able to determine that it is only ME that can't see posts in the new instance.. as Admin I can, and another admin can (at least)
Thanks for the prompt reply!
