Reinaldo Borin
Hello, I have problem to define rare cards in the deck.
This deck has 12 cards, 3 rare.
I've tried almost everything, or only the first is repeated normal Deck cards, or just has the rare, how should I proceed?
---------- Post added at 11:35 PM ---------- Previous post was at 10:51 PM ----------
I already try
Card 01: 900%
Card 02: 900%
Card 03: 900%
Card 04: 900%
Card 05: 900%
Card 06: 900%
Card 07: 900%
Card 08: 900%
Card 09: 900%
Card 10: 100% (rare)
Card 11: 100% (rare)
Card 12: 100% (rare)
i only received the Card 01 on random pick.
The way the system works is it runs through each card level in turn and sees if it hits the chance for that level.
As you have level 1 set to 900% then 9 times out of 10 it will grab a level 1 card. Whenever it doesn't it's almost certain to grab a level 2 card.
What you should do instead is try to use a total of 1000% over ALL of the card levels, like this:
Level 1: 250%
Level 2: 200% (450 total)
Level 3: 150% (600 total)
Level 4: 100% (700 total)
Level 5: 75% (775 total)
Level 6: 50% (825 total)
Level 7: 50% (875 total)
Level 8: 25% (900 total)
Level 9: 25% (925 total)
Level 10: 25% (950 total)
Level 11: 25% (975 total)
Level 12: 25% (1000 total)
That would much better accomplish what you're trying to do, though the chances of getting all the way down to level 12 would still be TINY.
It's usually a good idea to split decks up into a few different packs (e.g beginner, intermediate, expert, master) each focusing on 3-4 levels to get a good balance.
I go try, i say deck.
this is Third pack.
Level 1
Level 2
Level 3
---------- Post added at 12:49 PM ---------- Previous post was at 12:41 PM ----------
Trying
Card 01: 108%
Card 02: 108%
Card 03: 108%
Card 04: 108%
Card 05: 108%
Card 06: 108%
Card 07: 108%
Card 08: 108%
Card 09: 108%
Card 10: 8% (rare)
Card 11: 8% (rare)
Card 12: 8% (rare)
Those values do not add up to 1000% so using them means there's going to be a very small chance of people being awarded no cards :)
You could try:
Card 01: 108%
Card 02: 108%
Card 03: 108%
Card 04: 108%
Card 05: 108%
Card 06: 108%
Card 07: 108%
Card 08: 107%
Card 09: 107%
Card 10: 10% (rare)
Card 11: 10% (rare)
Card 12: 10% (rare)
That adds up to 1000%
