thanks. I will poke around with it and see what I can come up with. I appreciate the custom help!
---------- Post added at 14:20 ---------- Previous post was at 14:17 ----------
Are you aware of whether the image could be centered in the slider rather than aligned at the top left corner of the image? I think most photos have the subject in the center and seem to get clipped. (I have it set to some good forums for attached images now...)
---------- Post added 18th March 2012 at 12:18 ---------- Previous post was 17th March 2012 at 14:20 ----------
I just purchased the pro version. Before I install that, is there a change I need to make to deal with the forum problem I was having (hook location)?
I think I got it ...I moved Parse Templates to forumhome_start.... sound right?
To answer your question on image placement, a future version with better image management is on the horizon. And yes, your fix for the hook is correct.
Legacy vBSlider
