Not a problem, I suspected I would run into issues with custom skins and the mod, as I use a stock vB navbar template with a few things added to it, and some custom skins write their own navbar template, which when the mod is enabled, it uses my navbar template and not the one from the style, causing the display issues.
Hi Ozzy, i have the same problem with my PurevB template, is it possible to fix it ?
I send you temp access now.
screenshot how it was :
I do believe it is all good now. It looks like the one in your screen shot.
And thanks for having a English language on your site, make it much easier for me to navigate. :)
Thank you Ozzy. We have a last problem on the search box : we have the search box and advanced search two time in the header. We would like to remove the top one :
Best regards,
Olivier
Hi Ozzy, i've seen you updated my site last night, seems to be very good with the skins.
So now i define 2 navbar in vBNavTab but when i change any menu element it disapear from the menu 1 even 2.
How can i show the second menu ?
Regards,
Olivier
I dunno if it is possible with that style, I will need some time to figure that one out.
It would probably be easier if you could email me the complete style, and I can test it out on my dev console, so I am not making alot of changes on your site and confusing your members.
Thank you, just sent the email.
Regards,
Olivier
I could look into it for you, just a heads up though, it's best to start your own thread so the posts get flagged as a new issue. Replying to someone else's posts sometimes don't get seen
If you use a .htaccess password protection for your AdminCP directory, it is recommended that you create a new authorized user for DBTech and remove this user once the issue has been solved.
Legacy vBNavTabs
