Trekkan
If you have to always have the latest and greatest, expect problems.
If you can't handle that, it's no one else's problem, use the big boy pants.
If you aren't testing things before you go to production (regardless of even *IF* something/one says it'll work), its your problem. What I mean by this is, try it. If it doesn't work, you know it doesn't work. If you think that you should only rely on the testing DBT (or any company does) instead of your own specific testing, you're doing it wrong. Every environment is different, etc...
If you don't see anywhere specifically stated that Mod X works with version Y of vB, assume it doesn't work.
Arguing about semantics is how you get called a "troll", whether you like being called one or not. You've had your answer, be it direct, implied or sideways. If you choose not not to accept the answer, again, your choice.
Ohh, I'm just a paying customer too, not that that matters in any way.
