motorman
Hi Guys,
Having problems with my DragonByte Tech: SEO - Generate XML Sitemap scheduled task.
I can manually build the sitemaps and they work without error.
When generating them from the weekly scheduled task nothing is output.
I'm on DBSEO version: 1.0.7
Any help would be appreciated.
Thanks.
Please check your error log for any indication of what might be happening, otherwise try to reduce the number of items per page to 10000 or lower.
What logs are you talking about?
I don't get why I would need to reduce the amount of items per page when it run's fine manually?
Your server's error log. On a CentOS/Apache system, it's usually found at /usr/local/apache/logs/error_log.
Because the cron job is different from running it manually. The cron job is attempting to run it in the background, while a member is loading a forum page. Naturally, the server then has to both run the forum itself AND the sitemap build cron job, as opposed to just the sitemap build cron job.
