Lounge
Hi again :cool:
I also got a problem using the flash upload option. I choose a category, put a title and message and select a file. The extension mime-type is mp3 - and was uploading correctly till one hour ago.
If I choose a file - the file will be loaded in the que on the left of the 'select file' button. Pressing on 'upload file' there won't happen anything. The status 'pending...' keeps displaying.
In my firebug console - I receive the following error message:
G is null
},_replaceClass:function(y,x){var Y,AB...eturn new YAHOO.util.Region(C,D,A,B);
yuiloa...s?v=413 (rule 12)
G is null
http://www.dj-lounge.nl/community/clientscript/yui/yuiloader-dom-event/yuiloader-dom-event.js?v=413
Line 12
Could you please take a look at this? :)
Hi again :cool:
G is null
G is null
Line 12
Do you use any plugins that compress javascript? Something seems to be messing up the YUI library here.
As far as I know I am not using any javascript compressions.
Hey Lounge,
Sorry for the delay. I haven't been able to pin-point this issue thus far. Is this happening on all browsers for you? Could you try deleting the cache on your browser then reloading the upload page and see if that helps you. Also, do you have any browser plugins that interfere with javascript?
Hey Lounge,
Hello David, sorry for the delay! Yes this is happening on all browsers - I checked Firefox 4, Chrome, Internet Explorer and Safari so far. All browsers won't upload the file. I disabled all plugins on my site, except vBDownloads and the problem keeps coming. I cleaned up my cache from the browsers and rebooted the computer. I also tried it on a other computer with windows xp. Somehow the http://www.dj-lounge.nl/community/clientscript/yui/yuiloader-dom-event/yuiloader-dom-event.js?v=413 is the cause of this problem. Would you please check the website to try to solve this problem? :)
Legacy vBDownloads
