Former Developer
Sounds good. You don't need to run the XML through on a PL (Patch Level) update it's just the files that needed uploading. The issue was that instead of adding to a template hook I was overwriting it...
Not good for other mods. You won't notice the change unless you are running a mod that modifies the template hook surrounding the forums bit.
