Depending on the reason it doesn't work, it may or may not be a bug. Not working doesn't by default make it a bug. It could just be some compatibility issue, something missing, etc. As I use the mod on my forums and the sound works, it works here, etc (on the browsers mentioned), that is why it can't immediately be called a bug. However Fillip H. will have to check it out and you can be assured that if it's a bug, he'll get it fixed. DBT has simply the best support I've ever come across for a company, especially one their size, so don't give up hope or think they won't try and help, they'll do everything they can. =)
