I missed that. Is that a NO ?
Too bad our community wasted money on this, because the only thing we bought it for is not working as expected, but hey, thats life :-)
Are there any around that support attachements AND images in PM's ?
Are there any mods around that support attachements AND images in PM's ?
It was a yes.
There is no other mod that allows attachments in PM's that works.
In the next update the adding of images via the img button, from computer, will be supported.
If all goes to plan it will be Friday, but that is not set in stone as I am trying to track down other issues.
Looks like it will be next Friday, got tied up at work and trying to track down another issue.
Dont worry Ozzy. thats ok.
I assume you are referring to the server load issue. I am kind of worried about that too. Although we where just testing the mod (only admins and moderators could use the features) I decided to disable the plugin for now. But of course I am looking fw to enable it again.
No server load issue should be fixed, re download the product and upload dbtech/vbsuper_pm/hooks/preview/template_render_output.php
I was referring to the image thing, to be able to upload images from computer using the image button.
DF031 I have ran into some personal issues that is going to delay the release of an update for a bit. So I don't want you to be sitting waiting, I have changed a file to make it work. Redownload the zip, and upload dbtech/vbsuper_pm_pro/hooks/pmattach/editor_toolbar_start.php
That should allow you to upload images from your computer using the Insert Image button now.
Hi Ozzy, I have been away from home for a long time. SO only today I will have time to check this out.
THANKS a lot for the great service.
Legacy vBSuper PM's
